bobinyelm
Apr 30, 2015Explorer
dougrainer wrote:
1996---Take the cover off the rear main control module. IF the Epoxy resin on that module board is beige/tan, the ONLY fix is to replace the Module board. Those years (1993-1997) were the years Dometic had bad module boards that Intermittantly went to check for LP,EVEN IF ON AUTO and not calling for LP. There are 2 parts- The Module (updated) and a Ground Loop harness that needs installed also. If your Module board is NOT beige but greenish in color(meaning that the board is the updated module board), then do what Chris advised. Doug
Yes, I had a '96 Lance w/ a tan board that went bad. This one is green.
I removed the igniter module and tested it w/ a battery, and it worked fine. I then checked the wires (black and yellow) to the igniter from the board, and it supplied 12v.
I re-hooked the wires up, and its now working perfectly and lighting the gas immediately. Bad connection? though the push-on spade connectors looked clean.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
