dougrainer
May 01, 2015Nomad
bobinyelm wrote:dougrainer wrote:
1996---Take the cover off the rear main control module. IF the Epoxy resin on that module board is beige/tan, the ONLY fix is to replace the Module board. Those years (1993-1997) were the years Dometic had bad module boards that Intermittantly went to check for LP,EVEN IF ON AUTO and not calling for LP. There are 2 parts- The Module (updated) and a Ground Loop harness that needs installed also. If your Module board is NOT beige but greenish in color(meaning that the board is the updated module board), then do what Chris advised. Doug
So if I have a green board (I do), does that mean I also have the updated harness I wonder?
Yes, you do. 20 years ago the harness was sold separately. I just found out yesterday that when you order the Module board for your specific model number, the wire kit comes with the new module. Doug
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
