Charlie_D_
May 05, 2015Explorer
Tapered bearings do not normally require a press fit because the thrust set should place enough pressure in the roller bearing so that bearing does not turn on the shaft.
A slight press, and it sounds like that is what you have, should be O.K. If it will go completely in and engage the cup I would set the bearing the same as the others. As Donn said, too loose is better than too tight. If in doubt, sand the shaft with emery cloth.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
