We have a pole barn at our home where we park our 5er with 30amp service. I had a 30amp receptacle installed also to keep the rig plugged in during camping season so the fridge stays on and the smart...
It would be even better if you didn't run both rigs through a 50' extension cable and the adapters. If it's going to be a permanent set up, why not install a second 30A outlet in the box (if room, or get a bigger box)? Less chance for bad connections and tripping over long cables. If you do have all the adapters you may want to connect them, then stick them in a garbage bag to somewhat protect them from the weather, rain, etc.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
