Super_Dave's avatar
Super_Dave
Explorer II
May 15, 2013
need answer to common frig question
Can someone remind me what the proper location of the sensor on the fins is? Was it very top = colder?
  • My Norcold just has one temp control on the door panel (1-9). Last year the freezer section was working correctly but the frig was on the warm side. I'm hoping that it is something as easy as moving the thermistor up. My wife usually wipes the entire frig out after trips and it is quite possible that she could have bumped it out of place.
  • If you have a temp control adjustment on upper panel (1-5 etc.) then just make sure the bulb end of thermistor just protrudes out top of clip and then clip it to right fin mid-position.
    IF you have a fridge that you can NOT adjust temp on upper panel (pre-set temp control) then clip thermistor on right fin and move up to make fridge section cooler.....down to make fridge section less cool (should be a 'label' on side wall)
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
