VilleDeal's avatar
VilleDeal
Explorer II
Jan 21, 2020
NEED ASSISTANCE... ATWOOD AFMD FURNACE
I have a 2018 class A gas unit with an Atwood afm series furnace. My problem is that it was sooting up and smelling, even to the point of sounding off the CO alarm. I thought I had a dirt dauber problem maybe so I took the unit completely apart and flushed the heat tubes. I was wrong and that is not the issue. Ran a snake from stem to stern through it and got nothing at all. Flushed it with water also and got nothing but good flow. Here where my plot thickens. Not only have I not found the original problem, but now have another one. After putting it all back together, I now have a problem with nothing at all happening when turning the heater on. I checked the wiring diagram and see not issue, however it is possible that I am overlooking something. When we first put it back together I got a single flash light on the circuit board which pointed to the limit switch. Now though, after swapping out a couple of wires that were put in the wrong place initially, I get nothing. Any ideas? Could the limit switch getting wet during the flush, could it be stuck open not allowing the circuit to be complete upon startup. ALSO, could someone send a picture of their circuit board just to make sure the wiring is correct?
Having RV issues? Connect with others who have been in your shoes.24,303 PostsLatest Activity: Aug 20, 2025
