Winged_One
Sep 24, 2013Explorer
Need battery/leveling system help
Problem:  Battery charge is dropping from 12.7 to 10 and below when running the lippert leveling system.
Background: Added a second 12volt batttery (same 550 CCA) type to 5th this year. One battery is 2 years old, the other less than 1 year. Also, added a connector for Battery Tender Jr.
Status: The 5th is at home. Battery's were at full 13.4 volts when on the 50 amp cord to 20 amp connection at home. Battery connection to trailer turned off.
Yesterday, removed 50 amp cord and hooked up Battery Tender Jr. Showed green. Battery connection turned to on.
Today, turned on lippert system, it showed 12.7 volts. Went to manually lift the rear 4 jacks. System immediately showed 10.6 volts dropping to below 10 and shutting down after about 10 -15 seconds of lift.
Checked batteries. All at proper water level. Checked with hydrometer and none of the cells showed dead or dying.
Batteries are connected to trailer, positive to one battery, negative to the other battery (changed from my way of both to one battery by RV dealer who said their way was better).
I don't understand what is wrong (obviously). Suggestions?
