Charlie_D_
Aug 10, 2017Explorer
Have you checked the taper on the nuts? Not all nuts have the same taper. Another issue I had was installing acorn nuts that did not clear the bore of the hole. By that I mean the edge of the hex on the nut contacted the side countersink of the hub. That did not allow the taper of the nut to contact the area of the hub that it should have.
Heard a noise when slowing down. Found that 3 studs had broke and wheel was wobbling. Lucky I caught it before the wheel came off.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
