Kayteg1
Aug 14, 2017Explorer II
The title is misleading as OP talks about wheel centering.
Centering is determinate by hub design and you can't change it other than changing the hub.
In case of lug shearing, when they were torqued to 90 ft-lb I can only guess they were over-torqued in the past and now break with metal fatigue.
Would order quality bolt and that should solve the issue.
Wheel bolts usually have safety factor about 5, so it takes a lot to have one broken.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
