ktmrfs wrote:
pickjare wrote:
Consider how many cars and trucks on the road have wheels with all sorts of different offsets. I am not an engineer, but if wheel offset caused, or cured, wheel studs from breaking, I think we would have learned this from them. look at your wheel lug holes real close. If any one is elongated or worn, the wheel needs replaced. If every hole is good you might try retorquing the nuts after towing 10 miles--or 100 miles or both.
well...... virtually all cars and light trucks on the road today have hub centric wheels. that is the wheel hub is a very tight fit to the axle hub. So..... the hub takes ALL the vertical load on the axle, the lugs keep it from sliding off and take any horizontal load.
Virtually all utility and travel trailers (U-haul is one exception, most or all uhaul trailers have hub centric wheels) have LUG centric wheels, so the center is a loose fit on the hub so the lugs must take ALL the vertical AND horizontal forces on the wheel. Big difference.
that's one reason retorquing is so important on trailers. And the OP isn't the first person to have problems with lugs shearing on trailer axles. if lug nuts get loose it doesn't take long for the lug centric wheel to beat the **** out of the lugs.
I suspect any non zero offset puts even more force on the lugs.
Hub centric or lug centric refers to how a wheel is centered to the hub so they rotate on same axis. If lug nuts are conical, then lugs decide where wheel centers onto hub--lug centric. If lug nuts are not conical--they have a flat washer built in to the lug nut--then the nut and stud don't position the wheel onto hub. In that case, called hub centric, and only that case, it matters that the wheel fits tight to the hub as this centers its axis to the hub as they turn. This is how ford super dutys have been for years. This is how semi trucks are--hub centric. But, pretty much every other car and truck out there will be lug centric. That center hole in the wheel and its fit to the hub have nothing to do with centering the two parts together. As lug nuts are tightened in the proper sequence, the hub and wheel axis are matched together.
I believe it is incorrect to say "virtually all cars and trucks on the road today are hub centric." Ford super duty trucks are only vehicle I know of that are hub centric. Everything else uses conical lug nut and that is what determines where a wheel lines up with a hub.
