CA_Traveler
Jul 13, 2019Explorer III
wa8yxm wrote:
I like the Hard Wired over the Portables for two reasons neither is technical
The ratings are virtully identicll
1 With the HW you are secure you do not need to worry about it "Growing legs" and walking off
2: Unforgettable, since it is always there.
3: It's always on w/o any effort. And requires only 1 plug in not 2 like a portable.
4: The PI HW50C remote is inside or in the basement or both if you buy 2 remotes and constantly displays amps, volts, frequency, past and present errors. Note past error like low voltage is a red flag when you return to the rig as the unit reconnects when the voltage is OK. And the remote has a bypass switch that disables disconnect but not surge protection.
5: Wiring is required of course including the data cable to the remote which is one reason the portable unit might be chosen.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 22, 2025
