A week ago i noticed rv was struggling to maintain fuel pressure and rv would start then die after a few mins. Called rv mobile mechanic and after doing his diagnostics he felt it was definitely a ba...
It might be time to go to a heavy truck service center. You can start with Ford. I'm assuming you can keep it running long enough to drive it to the shop:
Not all heavy truck centers (Ford or independent) will work on motorhomes anymore. If that's the case when you call them, tell them that the problem appears to be isolated to the fuel system. They may take the job if the problem is not too big.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
