A week ago i noticed rv was struggling to maintain fuel pressure and rv would start then die after a few mins. Called rv mobile mechanic and after doing his diagnostics he felt it was definitely a ba...
It sounds like you have one of the four things needed to make the engine operate:the fuel. Assuming the pistons are working and making compression, that leaves air and spark. Ny SWAG is ignition coil or ignition module/distributor.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
