pianotuna
Jun 18, 2017Nomad III
Are you wanting to run everything on 120 volts, or are you willing to use propane?
If willing to use propane, then I'd get the Champion 3400 watt inverter generator with remote electric start. I'd add a 3000 watt hybrid inverter/charger.
I'd add easy start kits to each air conditioner. (Microair easy start).
If not willing to use propane, a 4500 watt inverter generator should run everything. Both Honda and Yamaha make that size.
I'd add a hybrid inverter charger such as the Victron, Magnum, or Master. I'd change to a 24 volt battery bank.
