RSD559
Jun 22, 2017Explorer
MrWizard wrote:
Check with Supergen.com , they have an extended run system for the champion, with a pump operated from engine vacuum
It does not have a lot of lift
Generator and extended tank need to be nearly level
Both on ground, truck bed, etc..
But it's not gravity feed, no special cap
Uses an add-on nipple for connecting the external tank fuel line
Don't know how well that works with t the multi fuel system
Whether or not there are any complications
Best to ask them
There is no Supergen.com. There is a SupergenProducts.com, but I can't find an extended run kit. Could you post a link? Thanks.
