Toogreys
Nov 26, 2014Explorer
The slide safety switch was my first thought too. I've run it in and out a couple times still comes in looking like it's still got a bit of a higher gap between floor abnd slide. Ran the slide all the way back out and still couldn't start it with it all the way out. Is there a way to reset the switch?
I've tried moving the gear shift around and tried to start it in both park and neutral with no luck but will try again.
Took the starter relay into a parts store and it checked out ok. They mentioned maybe the starter but I had no indication of a starter problem. Always started first time every time until now.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
