Toogreys
Nov 26, 2014Explorer
YC 1 wrote:
Try putting it in neutral in order to jostle the transmission switch. Step on the brake several times and hold to jostle that switch.
Do your slides go in and out with the engine running? If not it could be a lock out switch.
Normally I have the engine running when I pull in or out the slides. In fact I had it running when I pulled them in this last time. I shut off the engine and then couldn't get it to start .again. However I could run the slides in and out while the engine was off also. Tried to do that a couple times to see if I could reset something. When I turn the key all the instrument panel lights come on and the buzzing etc happens but nada.... No clicking, grinding ect. As one of the folks here said the engine won't crank. I called Good SAMs roadside assistance but they said they couldn't find anyone in my area. Could be because of Thanksgiving holaday.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
