YC_1
Nov 27, 2014Nomad
After downloading the users manual it is fairly useless. There is a fuse panel under the dash and one that says it is on a "bulkhead". It would have a couple of large solenoids and a fuse block. Use a 12 volt test light versus just looking at the fuses. Reach behind the dash if possible and jiggle the connection on the ignition switch. If I had a road map (schematic), I could be a bit more useful.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
