YC_1
Nov 27, 2014Nomad
You tube tutorial
The video is a good demonstration of how a starter works. You can use a small wire with the ends stripped slightly and hold it on the small terminal and touch the large cable. You will probably get a bit of spark and the noise will make you jump. There are inexpensive remote control starters that will do the same thing but from a safer distance.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
