bucky
Nov 29, 2014Explorer II
Smack the starter with a small hammer. IE don't break it. I've gotten them started that way more than you would believe if the brushes are stuck. It also means it is definitely the starter that is the problem. The starter still needs to be replaced, as the problem will occur more and more frequently until it quits for good.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
