Rockinfigs's avatar
Rockinfigs
Need help fast!
I'm out camping right now n my water heater stopped working.. I turn the switch on n nothing happens.. It doesn't ignite at all.. It was working fine when I got here.. Had hot water for 2 days but today the water is cold n the water heater will not ignite.. Is there a fuse in the main panel inside the hauler that might be out? I don't see a water heater fuse labeled. Thks
  • My hauler is a 2014 attitude 27cbg n atwood heater does not have a reset button inside the heater..my friends older ww has on but on mine I dont.
  • Try reset button,its outside push black rubber cover on side of the tank. then turn inside off and back on.
  • Yes i have plenty of propane n my stove works perfectly.
    When I turn it on the red light doesnt come on at all.
    And the battery is fully charged
  • Switch propane tanks or refill the ones you got. Is your battery fully charged up so it can activate the ignitor on the water heater to get the propane burning?
  • Does the red light come on when you turn on the switch?
    Do you have gas to the stove top and fridge?
    Not sure it applies to gas but there is the reset button outside under the black rubber cover.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
