Old-Biscuit
Jun 27, 2019Explorer III
The 'fill' adapter screws into that large nut which is part of the 80% ALUMINUM float valve assembly that is NO LONGER manufactured.
Take 2 wrenches....
ONE to fit the fill adapter
One to fit the large nut
Hold wrench/adapter and tighten wrench/large nut
Clockwise on adapter......counter-clockwise on large nut
Once propane in tank has been used...LP depleted
Unscrew fill adapter...clean up threads....wrap with Yellow tape (gas tape) and reinstall
Do not remove bolts holding square flange onto tank.....if you damage the aluminum float inside you will need to modify flange to accept new style float assembly or purchase/install new tank
Propane Tank Float Valve Fitting Modification
Take 2 wrenches....
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
