Fisherman
Aug 29, 2021Explorer
Well I've got the same trailer, the 3/8 or 1/4 ply inside on the walls doesn't make for a good base. There's nothing between the inner and outer walls. If you look close you will see where they used self tapping screws to hold the plywood to the steel beams. If you can't see them, you may have to remove the narrow strips where the joints are and staple them back after. A stud finder will work too. You're right about adding a 2x4 screwed to the beams to add strength.
