mkirsch
Aug 30, 2021Nomad II
You definitely want to attach to the framework of the trailer for anything that will be weight-bearing.
I've used self-tappers, but they need to be kept as short as possible so as to not poke through to the outside of the trailer.
A stud finder should be able to locate the framework, if you can't tell from the screws holding the paneling.
