path1
May 05, 2016Explorer
GordonThree wrote:
can you post a picture?
what do you mean the bolt came through... like the bolt head fits through a hole now that it's not supposed to? How about using a steel (and/or neoprene) washer?
Can't post pic right now.
At each corner of A/C (under the cover)there is a metal piece of metal that a bolt goes through in the A/C to keep it attached to roof. Way to much torque was put on the bolts. Head of one bolt broke through. Other 3 metal pieces are bent from to much torque. I would like to install another metal piece that fits into hole. If not I'll beef up with some metal pieces and get longer bolts. But I can't figure out the part name to look up what I need.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
