dougrainer
Oct 18, 2020Nomad
I would not install antifreeze in the icemaker mold. IF you winterize by blowing out the system. Connect air and manually cycle the Icemaker until you hear AIR blowing out inside the icemaker. If you use Antifreeze, then pump into the mold. The RV antifreeze leaves a small slime that takes numerous ice production to get rid of. Doug
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
