mrad
Oct 18, 2020Explorer II
dougrainer wrote:
I would not install antifreeze in the icemaker mold. IF you winterize by blowing out the system. Connect air and manually cycle the Icemaker until you hear AIR blowing out inside the icemaker. If you use Antifreeze, then pump into the mold. The RV antifreeze leaves a small slime that takes numerous ice production to get rid of. Doug
I like the air idea. Where do I look for the switch to manually cycle the system? This is our first time using the 5th wheel. I noticed when we get home which is 250 miles north, we will have temps in the mid 20's this week.
Thanks
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
