BFL13
Jan 22, 2020Explorer II
When the rocker switch is in "OFF", the solenoid works from the run circuit and key.
In key postion "ON" (but not in "START") you are already in "DUAL" (at least in my rig which has no rocker switch)
With the rocker, it must mean you don't get "DUAL" just from powering the solenoid, you need to push "DUAL" too. But why should that mean the rocker needs to get any power from the run circuit to pass along to the solenoid, which is already in the run circuit?
Does that mean the rocker itself needs 12v power to go from "OFF" to either MOM or DUAL?
