Old-Biscuit
Oct 01, 2020Explorer III
Picture is WAY too LARGE to fully see w/o scrolling back/forth up/down
From your description the 'chill grille' was installed backwards
Foam filter goes over the return side (open area where you can see evap coil)
Galvanized section with gasket goes over room discharge are (area where you can see fan blower wheel)
Slots....closed so air flows thru ducts
Slots....opened to direct cold air downward directly into area below ceiling grille
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
