time2roll
Sep 05, 2014Nomad
Are you planning to replace the 120vac/12vdc power center to be 50 amp rated?
http://www.bestconverter.com/PD4560-50-Amp-Power-Center-60-Amp-ConverterCharger
If you connect the generator to a NEMA 14-50 outlet you can just plug the main cord into the generator as needed. You are the manual transfer switch. Many motorhomes have this set up. Lowest cost.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
