Old-Biscuit
Nov 12, 2020Explorer III
enblethen wrote:
It is the two blue wires that come from the thermostat.
Red and yellow is the 12 volt DC supply.
Red is 12VDC + (positive)
Yellow is 12VDC - (negative)
Red supplies 12VDC+ to the thermostat via the On/Off CB Switch (local/on furnace frame) (Blue) and DC Power to 'power' circuit on board
Thermostat closes and sends DC+ back to circuit board (Blue) and sail switch/limit switch circuit
Connecting the 2 Blues wires at thermostat makes up 'run' circuit...bypassing thermostat
If Furnace runs (Fan/Flame/Heat) then thermostat is problem
If furnace does NOT...check if the on/off CB switch is tripped///push button reset
