dougrainer
Nov 17, 2020Nomad
In case you did not know, this is the RVP parameters for a HP system. Electric heat refers to HP. Doug
Why does my furnace come on when I am calling for heat pump?
When your thermostat is in the “Electric Heat” mode, if the set temperature is five or more degrees above what it shows as the room temperature; the thermostat will consider this too much of a load for an electric heat source and bring in the furnace to assist. The furnace will continue to run in this case, until the thermostat is satisfied. When the room temperature starts to drop again, the thermostat will try to proceed as normal, with just the electric heat (unless the difference between set point and room temperature reaches five degrees again).
PLEASE NOTE: Some of our thermostats will not run your electric heat and gas heat simultaneously. They will shut down the electric heat in order to bring in the gas heat.
Multiple consecutive calls for the furnace in the “Electric Heat” mode, can cause the thermostat to lock out the electric heat function for approximately two hours, triggering the furnace only when it needs heat. For more information on the Lockout function of the thermostat,
