mikestock
Nov 17, 2020Explorer
emblethen wrote:
I think the OP is in over his head!
So clairvoyant. You remind me of my wife.
I received the new Coleman thermostat today and installed the it. The circuit board was identical to the one I replaced and everything works perfectly. I still don't know the exact problem with the old thermostat but the new replacement solved it.
I had already eliminated the most common causes, the sail switch, the over temperature switch or dirt dabbers. The furnace would work when I applied 12v. using an external battery source, so it left only the thermostat or some unlikely cause, like rats.
