Flyfisherman128
Nov 18, 2020Explorer
So you are saying you got gas and spark but no fire.. I just put a new motor (it was going bad)I thought I want getting the correct air flow. I replaced the sail switch. Finally I replaced the igniter. I set the igniter where it was set at the factory. I still got it light intermittently. Not a good scenario for winter. I got out the owners manual and set the igniter as specified which was not even close to the way it came from the factory..yet it worked for 20 years.. To my surprise, problem solved.
