mikestock
Nov 19, 2020Explorer
No gas.
It seemed that most of the many posts about Suburban furnaces claimed the same problem as I had. The fan came on and I couldn't hear the igniter sparking above the fan noise. I could smell no gas on the outside. Most every bit of information I read said and the circuit diagram showed that the over temperature thermostat and the sail switch were usually the culprits. I removed the furnace from the housing and set it up on a bench, running it with a 12v battery. The spark looked good but, of course, there was no gas. Everything looked good so I reinstalled it and it was just like before. No gas. I let two wires touch and then nothing worked, no fan, no nothing. I found the glass fuse in the thermostat and I was back to the original situation; fan ran, no heat. I took a chance that it must be the thermostat so I bought a new one identical to the OEM and everything works. End of story. I don't really know what was wrong with the thermostat and don't care. It works.
I had a previous problem with this furnace about 3 years ago. Found, what felt like, a 1/4 lb dirt dabber nest in the duct. Put screens on the outside to prevent this from happening again.
