redwing10
Aug 06, 2015Explorer
You are dreaming if you think FR will be able to give you a ductwork diagram. You did not answer the question. DID YOU HAVE AIR FLOW BEFORE YOU CHANGED THE FURNACE? If so, then you have MISSED a Duct hose or 2. Do the Duct hoses go into the floor or are all run thru the cabinets? Doug
Doug,
A big thank you as I did not look at the bottom nor did the owner. We then took out the old FN and yes it had a cut out on bottom. We then cut out the bottom on new FN and know works like new.
The owner and I looked at each other and said how DUMB are we.
Owner and wife want to say a Big THANK YOU
Tom
Doug,
Tom
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
