DandD2015's avatar
DandD2015
Need some A/V advice
When we got the Chinook, I noticed it had an RCA home theater unit. It will play DVDs, tune FM stations, and has something like 50 watts per channel to four speakers. (RCA? Are they still around? I haven't associated them with quality in a long time so I was surprised to find it in the Chinook. But maybe they original unit died and this was the owner's replacement.) I didn't know how well the RCA worked but I figured if I needed to, I could replace it.
And sure enough it doesn't work very well...in fact it played one dvd a little then sort of HONNNNNNNNNKKKKKKKKKKKED, and stopped. Couldn't get the disc out. Had to unplug it, try again. Same thing. Tried a different DVD: similar results.
So I started looking for a unit to swap in. As I looked in the stores (Best Buy, Fry's) I was hoping to find something not too expensive but a decent brand. There was a Sony for about $130 at Best Buy but they don't carry it in store. I moseyed over to have a look at what they might have, anyway.
Come to find out: the manufacturers no longer use bare wire connections for the speakers? They actually have proprietary connections? The salesman at Fry's said that really, he wasn't even supposed to have the two units on the shelves---they're being phased out because everybody these days wants wireless speakers.
Great, so what now? I found one that has bare wire connections so I could do that for $249, which is more than I wanted to spend. If I tried putting the "proprietary wiring" in, replacing the existing stuff---that must be under the carpet, stapled here and there, etc. and it would just be a big mistake, wouldn't it?
Anybody else have to replace the home theater unit?
  • RCA.. friend of mine recently bought an RCA TV , so yeah..still around
    at least the brand name is
  • I think finding a (not too tall) receiver and pairing it with a DVD or Blu-Ray may be the way to go.
    As far as proprietary connectors go...well I'm not sure. I saw something like this:
    https://www.popscreen.com/prod/MTU2NTcwNDY4/UNIVERSAL-AFTERMARKET-SONY-PROPRIETARY-SPEAKER-CONNECTORS-FOR-ROUND-
    The ones that I saw were colored, as I recall. I'm surprised the manufacturers didn't come up with something like it sooner. The guy at Fry's said if you buy a Sony you'd have to have Sony speakers etc.
  • You could splice the new connectors onto your existing wiring and then another spice near the speakers.
    Doug
  • DrewE's avatar
    DrewE
    Explorer III
    I have never seen proprietary connectors on amplifier speaker outputs, except perhaps for car radios where sometimes they are bundled together with the other wires into a single connector and usually come with a mating connector with pigtails.
    There are a few standard connectors sometimes used with speakers, primarily in PA/pro audio settings (1/4" phone plugs/jacks and Speakon connectors) and in very low end home systems that are little more than boom boxes in pieces (RCA plugs, 1/8" or other sized phone plugs). Those are all readily available connectors.
    Even if it is proprietary wiring in some unusual cases, you can always splice wires. The wires themselves need not be anything special or proprietary for speakers.
  • You can buy an aftermarket player with wired speaker connections, most are that way. Your sales jerk was wrong. If these are 120V systems you're looking at, a receiver and a separate player are easier to find. If this is 12V, any aftermarket auto unit will work. You may need a pigtail to make wiring easier.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
