BFL13
May 27, 2021Explorer II
mrad wrote:
Sooooo....Do I need a bigger inverter/converter or more batteries. I should state the only time I will be using battery power would be if I brought the rig to work to leave from there.
Also, why does the Xantrex have an on/off button on the readout gauge? When should it be on, and when should it be off????
You are saying once the RV is on the road, your "alternator charging " will keep the voltage up enough for the inverter to handle the surge and load until you get back on shore power.
True if the inverter to batt wiring is fat enough--that is an issue.
For the rest, you don't need to buy anything or do anything if the time at work can be without opening the door of the already cold fridge. You can get ice to put in the fridge. You can wait till you get there and then buy foodstuff that needs to go in the fridge.
Or just don't take it to work and suffer the extra time from going back home to get the rig. What is worse?
Turn off the display when you are in storage with no shore power and want less draw from the batteries.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
