jamesroadking's avatar
Oct 22, 2017
Need some suggestions on upgrading batteries for dry camping
I'm thinking of modifying my Forest River Work and Play 30WRS toy hauling trailer to use for dry camping in the National Forest.
The trailer has big fresh, gray and black tank capacities, 2 @ 30 lb LP gas bottles and a single battery on the tongue.
I was thinking of purchasing four batteries and cabling them up for a lot more battery capacity. There's a generator rack on the tongue, but I was thinking that putting four batteries along with the two 30 lb. LP gas bottles is a lot of weight on the tongue.
Here's the questions, most these new batteries are sealed, so is their a fire / fume hazard if mounting them in the garage next to the wheel well box box on the same side and close to the trailer's stock inverter.
Anyone with thoughts on just keeping the extra batteries in the bed of my F250 while camping, (unloading when not camping) and running a jumper cable to the existing battery on the tongue.
Can the stock inverter charge 4 deep cycle batteries adequately?
If not what size battery charger do I need? I have a 30 amp generator that keep in the bed of the truck when RV'ing that I plan on using for charging the batteries every few days as needed.
Suggestions on battery size, type, and cabling the batteries up in series and parallel etc.
Thanks for your ideas and suggestion,
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Jan 18, 2026
