Muddydogs
Jul 19, 2015Explorer
I would get a screw about the same size as the hole or a self tapper screw a little bigger and insert it into the hole. A little silicone or the like on the screw head or even a piece of rubber to help the seal. Works for plastic gas tanks so I am sure it would work for a water tank.
This is common knowledge in the prepper community. If the world every falls apart and you need gas for a genny just take your drill and a few self tappers, poke a hole in your gas tank and take out what you need. When done run the screw back into the hole to seal it up.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
