full_mosey
Aug 14, 2013Explorer
portscanner wrote:
The last problem I have to work out is the best place to mount the controller is about 18" from the batteries and 6" from the fuse panel ........but there is a bathtub/shower between that location and the batteries. All the wiring from the batteries to the fuse panel goes via the basement.
There is some room that I can run the wire without having to completely tear the bottom of the camper off, but I got to be able to get a snake around the bathtub. Gonna have me some fun! (NOT!)
If a 20A system would work, you could look at the MS SS 20 Generation 3 multistage controller. It is approved for hazardous/outdoor locations and could be placed very close to the batteries. If you had AGMs, you could double sided tape it to the battery!
The SS model only does ambient temp comp so I use the SS 10 Gen 2 screwed to the inside of my AGM battery box.
HTH;
John
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
