Dutch_12078
Jun 22, 2015Explorer III
BurbMan wrote:
Issue with replacing the breaker is the one that is there now will be 30A double pole. If the OP changes that to a single pole there will now be an open blank in the cover, creating a safety issue. In this case it's important to cover that hole in the panel with a filler plate compatible with your brand of panel:
When I removed a double pole breaker at our cottage and replaced it with a single, I didn't have a filler available, so I installed a second single breaker that I had on hand in that space and marked it as a "Spare".
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
