DrewE
Jun 22, 2015Explorer III
DubV wrote:
If an overload on the one hooked up hot wire will trip the double pole, why do I need to replace it with a single pole? I'm guessing it's to "disconnect" the other capped hot wire?
So far as I know, you don't need to, at least from a safety standpoint. Code might for some rather obscure reason not permit it, or perhaps it just seems untidy to some people (as the dual-pole breaker implies a 240V or 120/240V circuit, not a 120V circuit). The NEC is available to read for free on the NFPA web site, though it requires jumping through a few hoops and registering to do so, and as is typical of complex laws it's not always the most readily understandable (nor most logically laid out) document.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
