BurbMan
Jun 23, 2015Explorer III
DrewE wrote:DubV wrote:
If an overload on the one hooked up hot wire will trip the double pole, why do I need to replace it with a single pole? I'm guessing it's to "disconnect" the other capped hot wire?
So far as I know, you don't need to, at least from a safety standpoint. Code might for some rather obscure reason not permit it, or perhaps it just seems untidy to some people (as the dual-pole breaker implies a 240V or 120/240V circuit, not a 120V circuit).
Agree 100%, there is no need to change the breaker. Not all double pole breakers mean a 240v circuit, they are also used for a pair of 120v circuits with a shared neutral.
In fact you could add TWO TT outlets from this circuit, each capable of delivering a full 30 amps of 120v power. Since the hot legs are out of phase with each other, both can share a common neutral. Black to the gold screw on outlet #1, red to the gold screw on outlet #2, and white to the sliver screws on both outlets, and bare to the green screws on both outlets.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
