wa8yxm
Jul 07, 2014Explorer III
Noel wrote:
If I disconnect (or connect) at a campground power post and the neutral pin comes out (or goes in).....first, before the live pins make contact.....is this a potential problem?
Can a surge occur?
Thanks
Proper procedure for plugging in or unplugging.
First: Make sure breakers are OFF.
Then insert or remove plug
IF inserting turn breaker on after insert.
Follow that procedure and it will not mater if you break the neutral first cause the hots are already broken.
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
