Lostagain__ExplorerAug 20, 2013Nev-R-LubeI found that Napp has an SKF bearing that they keep in stock. Part number FW115 with steel seal's and there only $43.99. My self, I replaced the axle's with Dexter Ez-lube hub's. After reading up on t...Show More
Denny___JamiExplorerAug 20, 2013Before I used that NAPA bearing I would check the weight rating, I used Dexter replacement bearings.Denny
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
Related Contentnev-r-lube bearingsDexter 8k axles, nev-r-lube bearingsNev R Lube bearingsnev-r-lube axlesNev R Lube bearing replacement
