agesilaus
Sep 29, 2019Explorer III
Our progressive converter has three reverse polarity fuses, same principal tho. Check the breakers. Progressive tells you to remove the positive cable from the converter then check the output. If it is 12V then it is working, if not it isn't.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
