wa8yxm
6 years agoExplorer III
For a GC-2 6.3 Volts is normal resting FULL CHARGE so clearly they are charged.
As others have suggested make sure you have them properly installed. I'm a tad confused if you have two 6 volt in series or 2 pair. You should show 12.6 volts from chassis cable to HOT cable (Ignore the connecting jumper)
Check switches and circuit breakers.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: 3 hours ago
