imgoin4it
Jul 07, 2017Explorer
I replaced a 13,000 BTU unit with the 15,000 atwood unit (my independent RV meck says actually it is closer to 18,000). Cools the front of our coach very well for the first time ever. Moore air, colder etc. I love it for that. The heat pump on mune is a waste of time and money. Not sure if it the unit or installation. I've talked to Atwood engineers and am led to be leave it is the unit. It will heat air at outlet to about 100-110 DEGREES then shut off. Will continue to cycle but will not run long enough to raise the temperature even when outside temp is 50 or 50 plus degrees. Also book says it does not produce heat if outside temp is about 45 degrees. On mine about is about 50 degrees. The engineer told me there were little tweets they could do to help it heat but my mech has not called them yet.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 21, 2026
