ScottG
Oct 27, 2014Nomad
Is the GFCI worn out? More often then not in our area they are worn to the point they can hardly stay on. It takes repeated flipping of the breaker to get them to set. Also the earliest GFCI's had a hard time with big motors. They appear as a fault to the gfci (because of the rule of ELI if you care to look it up)
If that's not it then try it with the AC off. Also recheck the wiring to the AC, you may have wires reversed.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 06, 2026
